Plot Spectrum
DaveyDoo
Plot Spectrum
Post by DaveyDoo » Fri Nov 16, 2007 3:50 pm
What is this used for?
alatham
Re: Plot Spectrum
Post by alatham » Fri Nov 16, 2007 11:33 pm
I recommend reading this wikipedia page on spectrograms.
Most Audacity users will probably benefit from the ability to find pops and clicks visually as described in this thread:
http://audacityteam.org/forum/viewtopic ... 5584#p5584
If you don't have any examples, you can generate some silence in Audacity, zoom way in, and use the pencil tool to drag a single sample all the way to the top of the track. Then zoom out and select the Spectrum view. If the quality is set high enough, you should see a bold red line where that click is. Even if this click were buried in a music signal, it would still show up clearly in the spectrum view.
