Where has Gverb gone?
I used gverb a lot in the past and can't find it anywhere in the latest audacity version. What happened to it ? Where can I get a decent reverb filter ?
Re: Where has Gverb gone?
That LADSPA pack has a ton if effects and will make your effects menu too long to fit onto one screen. If you're serious about audio editing, I suggest spending time exploring each one and picking only those you can expect to use. All the others you should take out of the Plug-Ins folder (not while Audacity is running) and store them elsewhere.
Either that or the display needs to be fixed for the effects menu. I'll post a note about that in the proper forum.
