persistent recording hum
michalthompson
Re: persistent recording hum
Post by michalthompson » Wed Nov 07, 2007 3:44 pm
At last I have a legitimate reason to drink on the job . . . what do you recommend I use as a lens cleaner?
Seriously, thanks for the followup information.
Michal
Post by kozikowski » Thu Nov 08, 2007 2:51 am
<<<what do you recommend I use as a lens cleaner?>>>
Eastman Kodak lens cleaner. But I wouldn't drink too much of that. That may greatly increase your awareness of the nearest men's room.
waxcylinder
Post by waxcylinder » Thu Nov 08, 2007 3:52 pm
Hey Koz, great advice about the cleaning of the male pins.
I was struggling today trying to work out why when recording from my TT that I was getting a significantly weaker signal on the R channel. Fiddled with the cartridge, re-seated the contacts on the pins, made sure the cartridge was aligned properly and that the stylus was clean - all to no avail (half an hour's work).
So then I swap over the L&R phono plugs from TT to amp - problem half goes away - THEN I remember your cleaning advice.
Some neat alcohol and a couple of paper towels - two minutes work - and hey presto, all is hunky dory.
So good advice for us all - keep your contacts clean ......
Post by kozikowski » Thu Nov 08, 2007 6:02 pm
<<<keep your contacts clean ......>>>
And don't touch them, either. The natural oils on your skin are slightly acidic and will corrode electrical contacts.
