Recording Question Please Help
Is it possible to record in stereo? I hit record, and a mono track comes up to record. I don't necessarily need the left and right to be different, just the same, as opposed to sound only coming out from one speaker when I play it back. Thanks for the help.
wsmith1952
Re: Recording Question Please Help
click on edit
preferences
audio I/O
set channels to 2
preferences
audio I/O
set channels to 2
If you're on a Mac, the option is under "Audacity". Some versions make you start the program up again after changing that setting. After one restart, the stereo setting should "stick."
<<<Is it possible to record in stereo?>>>
So, yes.
So, yes.
wsmith1952
sorry if I wrongly assumed PC
Yeah I have a PC. Thanks so much, I'm mad I couldn't figure that out by myself. Thanks again!
wsmith1952
Not a problem
that was the first thing I had to figure out, thats the only reason I knew.
