Thanks in advance.
DTS audio files, how to play them?
I have access to some files done as DTS, Ambisonics method, but I don't seem to be able to play them, is there a solution to this, or am I able to convert them so I can play them.
Thanks in advance.
Thanks in advance.
Re: DTS audio files, how to play them?
Thanks for those links, but I really need a simplistic how to covert DTS to a compatible music format using windows 98.
DTS music is a highly complex surround sound encoding scheme. I don't think there is any simple way to take the show sound apart short of recording the speaker signals two at a time with adapter cables. If you're trying to manage a two hour movie, that will take you over six hours.
