stevethefiddle wrote:In Audacity 1.2.x the Export bit depth is set in Preferences (not sure where off hand, perhaps in "Import/Export")
I have tried as you have said, but the file wont play in either WMP, or Switch.
I have the file exported as 44,100 and 24bits, but will not play.
The message in switch says cannot open the file because the required ACM codec is not installed on this PC.
Open the file in Windows Media Player to auto install the codec then re-attempt to load it.
In windows media player it sends a request for the codec but it has an error downloading the codec, then a message says class not registered.
So it looks like I can't play wave files other than 16bit, but hey no big deal as I can convert them to 16bit and they play fine.
Edit,
And I can't use the microsoft 32 bit float as the tag says after export the following Format: ACM Codec Not Installed 'IEEE Float'
Oh, but it still plays without the codec, so great.
