Broken? (stopped working out of nothing)
Smithers
Post by Smithers » Thu Jun 25, 2009 12:51 pm
I was using it today as usual, (have used it great without bugs for a while now), but today something really strange happened. It just stopped working...
If I import a file (wav or mp3) and hit play, nothing happens. Button is "pressed", but the cursor just stays at the beginning and I hear nothing. If I try to record something, it records good, I see the peaks of audio, but when I try to play back, the same thing happens.
If I try to export it (both wav and mp3) the file comes up a few seconds longer than the original, but is completely silent.
I restarted my computer twice now, have used lots of different audio files of both types, and still the problem is not solved.
Whats going on here?
Smithers
Re: Broken? (stopped working out of nothing)
Post by Smithers » Thu Jun 25, 2009 1:16 pm
Okay, I reinstalled and it fixed the problem.
But now, everytime I export something (wav or mp3), the clip is much longer than the original.
Example:(seconds)
Original 23 - Export 40
Original 2:52 - Export 4:49
Why is this happening?
Post by steve » Thu Jun 25, 2009 4:53 pm
Try resetting Audacity preferences according to this guide: http://audacityteam.org/wiki/index.php? ... o_defaults
Be careful if you are on Windows - if you make a mistake in the Windows registry you can cause lots of problems (use the "Safe Solution" method).
It may also be worth upgrading to Audacity 1.3.7
