Non-activated version
I have just downloaded and installed AVS Audio Editor and Audio Recorder. When I open either of them, there is a box telling me that this is a "Non-activated version". What does this mean ? ( I tried to find this in the FAQs and did not.) Thanks for explaining this.
waxcylinder
Re: Non-activated version
It means you haven't downloaded Audacity !
AVS is one of the advertisers on the Audacity download site - I suspect that you have pop-ups blocked so you are not seeing the actual; Audacity download (look at the messsage bar near the top of the window when you nest try).
See this thread: http://audacityteam.org/forum/viewtopic.php?f=23&t=8500
Thank you Wax Cylinder ! Of course, you are correct. Thank you again !
waxcylinder
No problem - many of us fall into this bear-trap !
