Народ помогите! как экспортировать многоканальный звук хоть в какой-нибудь формат FLAC WAV OGG хоть в какой-нибудь!
Ваш Audacity мне всё время грозится свести его в моно! зафиг он вообще нужен если звук нельзя нормально сохранить?!
People help! how to export multi-channel audio in some sort of format FLAC WAV OGG least in some!
Your Audacity threatens me all the time to bring it in mono! in this case it’s a useless program …
By default Audacity will export as mono if the project is mono (all the tracks are mono and centre panned), and will export as stereo if there are any stereo tracks or if any tracks are panned off-centre.
I searched through all the settings but nothing similar could not find.
Can you please make a screenshot of the settings where this wonderful option switched? or your stay to see this option you need to activate something else elsewhere?
Generally it is a mockery! default channels should remain as they were set up in the source file.
The vast majority of Audacity users (many millions of people) want to always export as mono or stereo. On that basis the developers decided that behaviour should be the default. If you wish to contribute to making Audacity better, please see here: Redirecting to: https://support.audacityteam.org/community/contributing
Thank you very much! without your screenshot I would did not understand
In general a very decent Audacity program, in many respects even more convenient Adobe Audition.
