Anyone find a way to do a vertical zoom? a maximum sizing default upon import would work. “fit track to height” or “zoom vertically” in increments would work. On my mac the “Expand all tracks” shortcut does nothing. HELP! haha thanks
Same here! Would be very nice to have that option again. Used that always in previous versions.
Yes. I really need this so I can visualise levels in quiet regions. Seems one of the most obvious things to have in an audio editor but I can’t find it.
Ah! Found it!
Tick View > “Show vertical Rulers”, which then displays on the right.
Click in the vertical ruler and you get Ruler format (logarithmic/linear) AND +, - & Reset for vertical display.
Not quite a slider, which would be better, but does the job.
Keyboard shortcuts for vertical zooming would be nice as well.
