I’m using an iMac with OS X 10.7.5 software installed. I installed Audacity from dmg.
While numbering song tracks I, as it turned out unfortunately, used the zoom tool to be sure I found the beginning of each song, per recommendation of the Audacity manual. Now, instead of the usual mouse pointer appearing on the screen, a tiny magnifying glass with a “+” in it appears and whenever I click the mouse the track keeps enlarging, as it’s meant to. That’s fine for finding the exact start of a song, but after doing that I want to be able to disable the zoom feature and restore the mouse pointer. I’ve tried everything I can think of, including selecting the “view>zoom normal” option.
Anybody have a suggestion?
