zoom R8 recorder 8 track
Hi, I have a zoom R8 8 track recorder, I made tracks and voice in recorder in which I did not use the computer, now that I have it how can you get it out of deck into the computer.
Valentine
If you are able to export WAV files from the Zoom (see the Zoom manual) then you will be able to import the WAV files into Audacity (File menu > Import)
