Good morning, folks.
I received a Zoom Q3HD camcorder for Christmas.
I want to use it to record my young grandson who plays in a band and would appreciate some help setting it up for the best sound results. I know very little about the options.
I have two options for Format - PCM and AAC. Is PCM the best choice?
Regarding Sample rate, the 3 options are 44.1, 48 and 96kHz. I presume the higher 96kHz is the best pick … Right?
And finally, I can select either 16 bit length or 24 bit length. Should I select 24?
So, the bottom line would be … PCM, 96kHz and 24 bit length.
Is this how the pros would set it up. I know very little about the above options so would dearly appreciate your feedback.
Thank you!
