zip will not export to directory
Hi’
I’ve had this problem with other files too. The zip program successfully unpacks the file and shows it in the window of the program but when it comes time to export or copy that file it says it can’t copy or send it to another directory but when I try to extract it again it says do you want to overwrite the file in the download directory but when I look in the download directory it’s not there. Strange!
As I said this happened with other programs and with other zip programs too.
Which program is this that you are talking about?
which program is this? Is this the same program as the first one, or a different program?
What says that? What is the exact message, and what program are you talking about?
Yes.
