z-noise plugin
I installed the Waves Z-Noise plugin but when I apply the changes, Audacity gives an error and crashes. I can get to the plugin but just can’t apply the changes. It does note a bug report but I can’t get to that to see what’s in it. Below is the file and location it notes in the error.
/var/folders/jj/y5qrwl0d1qzb34j34n9v_hp40000gn/T/Adacity_dbgrpt-11276-20181102T230229
If I click OK or Cancel it freezes the app and I have to force a stop.
Most Waves plug-ins don’t work in Audacity. There’s a list of supported host applications here: https://www.waves.com/support/tech-specs/supported-hosts
