I am a beginner in audacity so please forgive me in advance for any lack of clarity or understanding.
I have only used Audacity just a few times for very simple tasks. I’m on Windows 10, using Audacity 2.3.0.
I have a long audio file that I would like to split into small clips, in an automated way as much as possible.
The file has a bell sound (always exactly the same, that was added digitally, I suppose) at the end of each section that I would like to make a clip of.
I was wondering if there was an “easy” way to use this bell sound as a delimiter to divide the file and extract the clips.
The best would be if the bell sound itself gets cut out or if it is exported as individual “additional” clips that i could then discard.
Thank you for the reply.
I was also wondering if there was a way so that I could mark the file while listening pressing a button and then export based on those marks.
