I’m running Audacity 21.2 on Windows 6 (280Gh, 4 Gb installed, 32-bit) from the .exe installer.
I’m going from a Tascam 4-track into a Behringer Ultramizer and then into the blue stereo-in at the back of my computer (an HP).
I’m getting a good, clear, strong audio in stereo from the tape, and the red time-line is moving, but no waveform and the audio won’t record. I can’t get the stereo levels to respond, even after hitting the black arrow under the microphone. Still get a great signal while the time line moves, though.
Can you guide me through what I’m doing wrong? Is it possible that my copy of Windows 7 is at fault? All my drivers are up to date. Thanks.
Audacity 21.2
… or possibly even 2.1.2?
Windows 6
I know about Windows 7…
Are either the playback or the record sound meters doing anything?
Sorry, 2.1.2 and Windows 7. Sound meters are doing nothing at all.
Yes, line-in is my recording device.
I went over everything, and I’m still not sure what I changed (sorry), but it all works just fine now, levels, signal, etc. Had to change the output to hear it. Sounds great, thanks a lot!
