i am trying to use an Akai Pro EIE (electronic interface expander), downloaded the sound driver and everything… audacity wont recognize or discover it so i cant use it. how can i get it to be seen by the program so that i can select it as my sound driver???
Ensure that the Akai is connected to the computer and recognised by Windows before you open Audacity.
If you start Audacity first you will need to “Rescan for audio devices” (Transport menu) after the Akai has been recognised by Windows.
yeah it was being recognized by windows, there’s a “panel” that is installed with the sound driver and it shows whether or not is picking anything up. It works fine with wavepad sound editor but i rather use audacity so im frustrated. I will try to rescan for it though and see if it can recognize it
For the “host” setting in the device toolbar, try the MME option - that is usually the most compatible.
If still no joy, select “Audio device info” in the Audacity help menu and copy and paste the contents into your reply. That will tell us if Audacity can see your device at all.
yeah i dont see it here
Default capture device number: 1
Default playback device number: 4
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.090000
Low Output Latency: 0.090000
High Input Latency: 0.180000
High Output Latency: 0.180000
Supported Rates:
Device ID: 1
Device name: Integrated Microphone Array (ID
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Device name: Stereo Mix (IDT High Definition
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 4
Device name: Speakers / Headphones (IDT High
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 5
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Input channels: 2
Output channels: 0
Low Input Latency: 0.120000
Low Output Latency: 0.000000
High Input Latency: 0.240000
High Output Latency: 0.000000
Supported Rates:
Device ID: 6
Device name: Integrated Microphone Array (IDT High Definition Audio CODEC)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 7
Device name: Stereo Mix (IDT High Definition Audio CODEC)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 8
Device name: Primary Sound Driver
Input channels: 0
Output channels: 2
Low Input Latency: 0.000000
Low Output Latency: 0.120000
High Input Latency: 0.000000
High Output Latency: 0.240000
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 9
Device name: Speakers / Headphones (IDT High Definition Audio CODEC)
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 10
Host name: Windows WASAPI
Input channels: 0
Output channels: 2
Low Output Latency: 0.003000
High Output Latency: 0.010000
Supported Rates:
48000
Device ID: 11
Device name: Speakers / Headphones (IDT High Definition Audio CODEC) (loopback)
Input channels: 2
Output channels: 0
Low Input Latency: 0.003000
High Input Latency: 0.010000
Supported Rates:
Device ID: 12
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 13
Input channels: 2
Output channels: 0
Supported Rates:
Selected capture device: 1 - Integrated Microphone Array (ID
Selected playback device: 4 - Speakers / Headphones (IDT High
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available capture sources:
0 - Master
Available playback volumes:
0 - PCM
Capture volume is native
Playback volume is native
My guess is that you have installed ASIO drivers for the Akai, but no “Windows” drivers.
Audacity cannot be shipped with support for ASIO due to licensing restrictions, so for Audacity to be able to use the device you must have Windows USB drivers installed for it.
I suggest that you check here to see that you have the latest drivers: http://www.akaipro.com/product/eiepro#downloads (2.9.55)
Then reinstall the drivers, following the instructions in the manual very carefully. it is often important to do things in the right order when installing drivers, so read the instructions before you start.
When it’s all done, reboot the computer.
the Akai EIE that is not pro, doesn’t have drivers, or it contains its own. So it’s not a driver issue. Audacity recognizes my Akai EIE but I can’t figure out how to get it to record all 4 tracks simotaniously.
You may need to set the “host” to “WASAPI” in the device toolbar and then set the “number of channels” to “4”.
