WMP Recording - Mic Question
Newbie here…
I’m recording from Windows Media Player into Audacity and the default Imput Device is my internal microphone…
First, I don’t want to listen to it record (long audiobook), but if I mute speakers etc it doesn’t record.
Second, since the mic is open, room noise and voices are picked up
Can’t is use a direct connection??? What are the WSAudio Devices??? Is there anyway around this?
TIA
Tom
Some computers allow recording music playing on the computer and some don’t. It’s not a guaranteed service.
http://manual.audacityteam.org/o/man/tutorial_recording_audio_playing_on_the_computer.html
I found a reference to stereo mix, (what ever that is) and enabled it in ‘recording devices’ and it works to record without using the mic.
Tom
