Downloaded Audacity (The latest) yet when trying to start it up I since receive the message “This app can’t run on your PC”/ To find a version for your PC check with the software publisher. I have Windows 10 with the exception that it is Windows 10 Pro. Any suggestions are appreciated…
James
Try the 32-bit installer - it should run on any current Windows computer.
To know it was that simple, just needed the 32-bit, I am extremely relieved, works fine and thank you so very much!
