windows 7 source?
how do i get the turntable connected as the source? the source icon does not give me the option. it is stuck on microphone
Do you have a USB turntable? Some other connection?
What computer do you have?
i have vibe sound vs-2006-mts turntable
Plug-in the USB connection before starting Audacity.
Then, select the USB device as your [u]Recording Device[/u]. (It usually says “USB CODEC” or “USB… Something”, but if you only have one USB audio device plugged-in that’s it.)
I Audacity can’t see it, right-click on the Windows Speaker/Volume icon and go to Recording Devices or (Input Devices) and make sure it shows-up and is enabled. If Windows finds it, Audacity usually finds it.
