windows 7 Audacity 2.3.3.
Hello, all. I was able to import and label two projects, which I saved on Audacity as SAVE PROJECT. Now, however, I cannot find them in File/ Open. I thought I would find it there. Instead it goes back to the location from which I imported such files prior to making the project on Audacity. Can someone please help me navigate to these two projects, which as I recall, I did not see any option to name, which seemed odd. Something is a bit off and I just can’t find the project(s).
Steven
Is the project listed in Audacity’s list of “recent files”? https://manual.audacityteam.org/man/file_menu_recent_files.html
As you are on Windows 7, this post may also be relevant for you: https://forum.audacityteam.org/t/cant-start-audacity/55439/2
