Windows 10
When will Audacity be available for Windows 10 like it is now for other window versions? Thank you. Paul
Audacity 2.1.2 works fine on Windows 10. Just make sure that you have the correct Windows 10 sound card drivers installed.
Thanks Steve for the info.
Are you able to send me the links for those drives?
Appreciate it.
Device “drivers” (not “drives”) are programs that provide an interface between the hardware (in this case, the sound card) and applications (in this case audio programs). Device drivers are specific to both the hardware and the operating system. That means that the sound card driver in your computer should be one that is written specifically to work with your sound card and your operating system.
If you recently bought a new computer with Windows 10 installed by the manufacturer, then there is a good chance that it will already have the correct drivers installed, and Audacity will work fine. If it’s not broken, don’t fix it.
If Audacity does not run correctly on your computer, then you should check that your sound card drivers are correct. If you are using a branded computer, then you need to go to the manufacturer’s website, look for downloads for your specific model number, and download the drivers for Windows 10. More information is available here: Missing features - Audacity Support
