Windows 10, with Audacity 2.4.2
Dear all,
I’m new to Audacity.
i’ve created some projects.
Every time I launch Audacity i have often the message : the last project had an issue and i have a retrieved project.
What shall I do, please?
thank you
regards
Yas
So I’m thinking you are seeing a message like this:
I would think that if you clicked the button “Discard Projects” that would be the end of it.
Is your project on your local machine or on a thumb drive or a network or the cloud? If it is not on your hard drive on your local machine, that could be at the root of your problems.
I don’t know if this would help, but if the situation continues, you could try tools > Reset Configuration. Also, it is a good idea to reboot and to check for Windows Updates from time to time.
