Hi!
I’m using Audacity 2.0.3, running on OS X 10.8.2.
Here is a screenshot of the problem:
Here is a screenshot of how it should look like:
What’s wrong exactly?
Thanks!
Hi!
Thanks!
Thanks!
Does that mean the reset of toolbars or reset of preferences solved the problem? It helps other users looking for a solution to know exactly how you solved it.
If you know of anything you did that created the problem (such as a window resize after moving toolbars) that would be useful to know too. We might be able to stop it happening.
Thanks,
