Hi so i was wondering if anyone happens to know if this https://www.thomann.de/gb/behringer_u_phoria_umc202hd.htm would work on Ubuntu 18.04.4. Audacity
I don’t have one to test, but I would expect it to work.
A quick search with Google returned this post on the LinuxMusicians forum: https://linuxmusicians.com/viewtopic.php?p=69180 (see second post)
I have the UMC22 model and it does work as a standard USB device but I have found that the volume comes in lower than I’d like and there is no “easy” way to adjust it. It will start peaking and clipping on the device itself but the volume recorded is around half-way up the volume meter of audacity. I’m not sure if the UMC202HD would have the same issue but it might. It works otherwise and the mic sounds good.
