Windows 10
Audacity: 2.3.2
Hi,
Will the ‘LePoulin Lextac amp VST plug-in’ work in Audacity?
I’ve copied the file (LeXtac.dll) to my Audacity Plug-in folder, at:
C:\Program Files (x86)\Audacity\Plug-Ins
I opened the Audacity ‘Effects’ folder, and ‘LeXtac’ is now listed as a ‘New’ available effect.
I selected ‘LeXtac’ and clicked [Enable] and ‘New’ changed to ‘Enabled’
Then I clicked [OK] but then a popup said:
Effects or command at C:\Program Files (x86)\Audacity\Plug-Ins\LeXtac.dll failed to register:
Could not load the library
Many thanks.
