using
Linux Mint 19
Audacity v2.2.1
Distribution’s release
audacity will not start up if Jack is running. There are error messages but when I try to include them in this forum, posting is blocked by Cloudflare. I will try to add them as an attachment.
A similar problem was reported at http://mxlinux.org/forum/viewtopic.php?t=43541 but the solution given there (set default-fragment-size-msec = 2 in /etc/pulse/daemon.conf) did not work for me.
Is Linux Mint your usual operating system? (Your profile says Mac OS)
That other topic is unrelated - they do not have Jack running.
Do you have Jack running? How did you start Jack?
Why are you using Jack?
Does Audacity work for you with PulseAudio?
I’m trying to use Audacity in conjunction with sound production and processing applications such as amsynth and Bristol, using Jack to connect. Jack is started using QjackCtl (version 0.4.5).
I tried it again with the QjackCtl Messages window open, and upon trying to start Audacity, I start getting this message repeatedly:
So you are saying that Audacity doesn’t work with Jack running, and doesn’t work when Jack is NOT running?
Do you mean that you can’t get Audacity to run at all (irrespective of Jack)?
That indicates that your computer is not running fast enough to maintain the audio stream.
