will not 'save project as...'
I save to Desktop with a new name for my project, no error message comes up, but either nothing is created on my Desktop. Very odd. Or, a file is created but under the same name as before. i.e. I would like NAME 1.2 instead of NAME 1 but it won’t create this new copy. Any ideas? thanks
What are you calling it? You can get very odd conditions if you violate Filename Hygiene.
Upper Case Letters, lower case letters, numbers, -dash-, and underscore. Those are the only safe characters to use in filenames. The Windows people have an additional list of forbidden words from the DOS era but Macs should be OK.
That help?
