Windows 7 Ultimate, Audacity 2.3 (er, the latest one)
Problem started with recipient telling me there was a weird thumping noise in my files. (Almost as if my computer wishes I played rap). I was showed the isolation, but it’s… not… here… Seriously I literally cannot find it here, so I downloaded the latest versions and reinstalled audacity, LAME, FFmpeg, and am about to put in a new version of Noisegate just in case.
All of a sudden I get the attached error, which upon looking I have no clue what to do about. So being as this is upon an update/install…
Yes, I’ve recreated it frequently. It happens when I export the file: either mp3 or wav, doesn’t matter.
I went in and disabled a bunch of plugins I never use, hoping that would work with no change. I also downloaded and installed the latest wxwidget, no change. I have no idea if this is effecting the final file or not, because I can’t find the thumping to begin with.
That’s good, but still, that error should not happen.
Were you exporting a stereo track when that error appeared? I’d like to be able to reproduce the problem (if possible) so that we can discover what the underlying problem is.
