Hi, great program (Audacity) but when I click on the help button and select the Manual (in browser) nothing happens except the help menu closes. I’m running windows 7 (64bit) and the latest version of Audacity. 2.0.6
I forgot to add that I also downloaded the full version for windows with the help files within, but they don’t come up when clicked on. WHY is this?
Download Audacity only from here: http://audacityteam.org/download/windows.
Install or reinstall Audacity from the above page. Make sure that half way through the installation process, you out a tick (checkmark) in “Reset Preferences”. Say yes when you launch Audacity after installation and it asks whether you want to reset preferences.
If there is still a problem then probably you don’t have HTML files associated correctly with your web browser. You can always go here http://manual.audacityteam.org/o/ to look at the Manual for the current version of Audacity. So when Audacity 2.1.0 comes out soon, the content of that site will change to refer to 2.1.0.
