Which SVN "revision" is 2.0.3 release version?
I would like to compile the new 2.0.3 release version with ASIO. Which revision number would it be (if possible to do it this way)? If not, is there another way to accomplish this? Thanks.
If you download now you don’t need to specify a revision number as the only updates since release are a couple of minor updates to the language translation files.
See here for how to build Audacity with ASIO support: http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface
Thanks for the quick reply. I’ve built ASIO version using current 2.0.4 revision; I just wanted a build that did not say “alpha”.
You’ll need the tagged release: http://code.google.com/p/audacity/source/browse/#svn%2Faudacity-src%2Ftags
Thank you, that worked except the repo is located at:
http://audacity.googlecode.com/svn/audacity-src/tags/
