Which effects did i add???
I am using Audacity 2.0.5, could someone pls tell me how to figure out which effects i used for my files in the past? If want to re-use or undo the effects.
Thanks in advance!
While the Audacity project is still open you can look in “View > History”.
Once the project is closed you are down to whatever you can remember, unless you wrote it down.
Thanks Steve,
Thats why i couldn’t find the used effects, i quess i will have to write it down next time!
Would you find it useful to be able to export the history to a text file while the project was open, or to have the history automatically saved when saving the project (without being able to undo/redo once the project was closed)?
