I want to record my set in rekordbox using audacity because of beatport streaming limitation on rekordbox. But the resulting audio loudness is way less than what the volume is if recording from rekordbox
You can run the Amplify or Normalize effect after recording.
Audacity has already pre-scanned your file, and Amplify will adjust by whatever change is needed for 0dB “maximized” peaks. Normalize defaults slightly lower for peaks of -1dB.
