I have Read and Watched multiple “apparent” fixes but non of them work. I have imported the raw data but after fixing the static it was only the original unedited audio with non of my changes. I have updated audacity. I have downloaded ffmpeg. I have tried what I feel like is everything. I save the project every time and a backup as well as saving it to the cloud but all of them show nothing when I open them in audacity also there is no pop up or error message when I save it. I have remade the beat again and again thinking it will save this time (definition of insanity) but it never does. I even exported a part of the song before I closed audacity and it is audible there. my computed storage isn’t full. I have had audacity for two days and it has only properly saved two projects : one with only a pre made instrumental imported which is completely unedited by me, and another one which I was just using to test if it was the file size or something, I have put no time into either and somehow they are the ones that save.
If anyone has any advice I would appreciate it
thanks
