Hi to All,
After a recent update sic I find I can no longer use this program. It used to be easy to import a file, set start and end points and cut out what was needed. Not now. I first had to contend with shutting off the quick marks or whatever they are called. Then I find I cannot just click to start select the bit I want and then cut it out. It no longer selects from the mouse. I don’t want to have to take a 3 year study course in how to use it. Or is that your plan? Make it so unuseable only fanboys can decipher it!
So Long, and Thanks for All the Fish.
Mark.
Did you write for help or just to vent.
Consider yourself vented.
Which program? Which update?
