So I’m trying to delete and edit a file. When deleting it says, Select the Audio for Delete key 2. What does that mean? And how do I get it so I can edit and delete something? Thanks!
Select the the audio you want to edit, e.g. using the cursor …
Then press the delete key on your keyboard , ( or “Ctrl”+“x” )
