Ways to fix Sound export recording In Audacity
Are you adding the files to the iTunes library as described here: http://manual.audacityteam.org/man/tutorial_exporting_to_itunes.html#iTunes
It sounds like a known Apple bug. You may need to export to the “Automatically add to iTunes” folder. See https://forum.audacityteam.org/t/itunes-audio-clips-truncated/42885/2 .
