Waves plug in error message. PLEASE HELP!
Hi All,
I have installed the waves debreather it is on my plugin list in audacity but when I try to enable it this error message appears…
effect or command at ksVW/aufx/BRTM/Waves:
Debreath (m) failed to register:
Could not initialise component
Any ideas what I need to do to fix it, please?
Thank you!
Some VST plugins do not work in Audcaity.
Reportedly “Waves V9 Debreath” works in Audacity.
There can be 32-bit & 64-bit versions of plug-ins, usually only one type will work on a machine.
Recently the Mac version of Audacity became 64-bit,
so may be worth updating to that if the Waves plug-in is only available as 64-bit.
