I am a complete newbie to Audacity
I am recording vinyl to computer
I’m using version 2.3.3
Windows 10 Pro
Using a turntable attached via usb to laptop
I’m having no trouble recording, splitting, exporting etc.
Everything fine
The problem is that when the music is recording the waveform goes no higher than about 0.3 and no lower than about -0.3.
Everything is clipped above or below those figures
It does appear to be clipped but you might need to zoom-in to see the waveform detail.
If the sound quality is OK the levels are not a problem and you can simply use the Amplify effect after recording.
I’m using a USB turntable
That’s bad news because the clipping is probably happening inside the turntable. What turntable do you have?
If there is an unamplified analog output you might be able to use that with a phono preamp and the line input on a regular soundcard, or some other hardware. The amplified (line-level) analog output probably matches what you’re seeing digitally so you’d need to bypass the internal electronics.
It’s a PROlectrix turntable which came with Audacity supplied
I’ve used it many times with Roxio Creator with no problems.
After upgrading to Windows 10 I found that Roxio was incompatible so decided to try Audacity
