Windows 8, Asus laptop, Audacity 2.0.5, Focusrite Scarlett 2i4 microphone unit
Out of the blue, Audacity displayed this symptom of not keeping microphone data or import
of a file in the program. Problem not correlated with install of other software around the
same time. Uninstalled Audacity, ran anti-virus utilities, re-downloaded Audacity from sourceforge.net (.exe version), reinstalled, rebooted machine. Problem persisted. After a few
seconds of recording or file import, Audacity purges data and goes flatline after a few seconds.
Just as you suspected, problem not with Audacity, per se, but with the designated temp directory
used by Audacity. Permissions on .AppsDataTempaudacity_temp somehow got messed up.
Is there a way to submit an enhancement request to add human readable error message upon
this condition, something like,
"Unable to write to temp directory, “<directory_path><directory_name>. Please check
directory permissions or Audacity Preference settings.”
Error msg:
.AppsDataTempaudacity_tempcanicreate is not writable
/* If the directory already exists, make sure it is writable */
wxLogNull logNo;
tempDir.AppendDir(wxT(“canicreate”));
if (!tempDir.Mkdir(0755)) {
wxMessageBox(
wxString::Format(_(“Directory %s is not writable”),
tempDir.GetPath().c_str()),
_(“Error”),
wxOK | wxICON_ERROR);
return false;
tempDir.Rmdir();
tempDir.RemoveLastDir();
“.” is not a valid path. The temp dir would default to
C:Users<your user name>AppDataLocalTempaudacity_temp
“AppsData” is not standard. You may want to run:
ECHO %Temp%
from a command prompt to see what that environment variable is pointing to.
Yes I can add your vote. But there can be many causes of Audacity not being able to write to its temporary directory. Permissions is not the only test.
Audacity actually interprets “.AppsData” as meaning it should create a temporary directory called “AppsData” in the folder it’s running from. But I think you must have typed that in yourself, correct?
