Waveform (db) not available just waveform
All I am offered when I right-click the vertical drop-down is
Multiview
Waveform
Spectrogram
There is no waveform (db) as others recommend to use. Can anyone help pleeeease? My audiobook keeps getting rejected because the background noise is not -6db.
What you have there is the context menu from the Track Control Panel - you need the context menu from the Vertical Scale:
Don’t ask me why the settings you need are in two different places …
A while back one of the devs thought it sensible to separate them, I always thought that was a bit daft.
Peter
