Wave peaks too low from USB turntable[SOLVED]
I am using version 2.05 with an audio technica usb turntable. Whether i record smooth jazz or an old rock Cream album I get a short wave height. I thought the wave should be between 0.0 and 1.0. My waves only go from 0.0 to about 0.10. What do I do to change that.
frank
Some USB turntables have a volume control underneath or on the base somewhere.
Try changing the Audacity “microphone” volume slider on the main window. Is it all the way up?
You can also go into Windows control panels and make sure they’re turned up.
I found out the usb turntable does this. I only had to go in and amplify the wave and all was normal.
