Here is explained of random data generation with WFC. https://robertheaton.com/2018/12/17/wavefunction-collapse-algorithm/
https://github.com/mxgmn/WaveFunctionCollapse
C++ fork : https://github.com/emilk/wfc
Could you add this algorithm in Audacity for new sound generation?
What if user could input spectrogram grid and use WFC algorithm to generate new sound?
I think it would need (midi) notes to improvise from, rather than a waveform.
If you’re looking for a grid to generate tunes, see … https://youtu.be/k8EfRXihiWg
Is there something for windows?
Let’s say you interpret a small grid of spectrogram as input data for WFC algorithm.
Trebor
4
It’s an online app. … http://earslap.com/page/otomata.html (flash required).
If one of the blocks in that grid was colored-in the result would be (band-limited) noise, not a musical note.
[ The Earslap guy has done variations-on-a theme fractal stuff
… https://web.archive.org/web/20110226201013/http://www.earslap.com/ ]
