**AUDACITY VERSION:**2.0.0
INSTALLATION FORMAT: Portable Apps
OPERATING SYSTEM: Win7 (System not allowing me to access more information / Using someone else’s computer)
ISSUE:
I taped a conference.Took 3 recordings using the ZOOM Model H2.
The following information was noted about the files:
Named: oo0.wav Length: Not Noted Size: 1,529,617
Named: 001.wav Length: 00:07:18 Size: 75,524
Named: 002.wav Length: 00:39:44 Size: 410,766
The largest and most important file when opened in Audacity,
- The Stereo tracks open up inside Audacity but there is no audio wave displayed on them.
- The file could not be played / heard.
ERROR MESSAGE:
There was no error message when opening the file.
The other two tracks are playing fine.
Suggestions??
Thanks in advance.
JJ
