WAV files won't import into Audacity
Windows 7, Audacity 2.0.6
I created my four audio files recording on the Zoom H6. Partway through the recording, the power went out. The files wouldn’t play in the recorder after that but I imported them onto my computer and they’ll play as WAV files in the Windows Player perfectly. However, if I try to import them into Audacity, no audio will show up. I tried importing as Raw Data and that just came out as static.
Any solutions to how to get Audacity to recognize the audio in these files?
Thank you!
https://www.youtube.com/results?search_query=Fix+a+Corrupt+Wav+Audio+File+in+Audacity+
As an alternative to figuring our the correct Raw Data settings, you can try installing FFmpeg from http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#ffdown. File > Import > Audio… then choose “FFmpeg-compatible files” in the “Files of type:” dropdown before selecting the file.
Given Media Player plays the files, the headers must be largely correct, so FFmpeg is quite likely to be able to decode it.
