I recorded wav file on my samsung galaxy s2 . use auto call recorder . setting was ( audio source : voice downlink).
but when I try to play it, it’s not wok . i open it in audacity 2.0.3 . but I coudn’t see the blue waves and no sound , while the file is 157 Mb .
You may be able to open the sound file if you install the FFMpeg software into Audacity. FFMpeg allows Audacity to recognize and open many more sound formats than Audacity alone.
I installed the FFMpeg software into Audacity as exlained. but it is not work … I export it as (*.mp3 ) but also it is not work … but I could see small green line in the output level bar.
When you import the file, do File > Import > Audio… and make sure you choose “FFmpeg-compatible files” before importing the file.
What does the waveform look like - is it a flat line or almost so? Is the file the correct length?
If the file is the correct length, you could try clicking in the Track Control Panel on the left to select all the track, then choose Effect > Amplify then click OK. Can you see or hear the file now?
If the file still gives problems, download MediaInfo from http://mediainfo.sourceforge.net/en/Download/Windows (get the version without installer) . Open the file in MediaInfo, press View > Text then copy the information and paste it in here.
You appear to have a perfectly valid WAV format recording of silence.
I’d guess that the problem is with the “auto call recorder”. I presume that the recording plays as silence in any other program?
all this ( even wav ) are work fine except when change setting to voice downlink or mic from the audio source setting.
For mic it’s silience although the file have a size ( on PC or mobile )
for voice downlink I can hear the comming voice but I can’t hear my voice. ( on PC or mobile )
but when choose voice up link it work fine . ( on PC or mobile )
As I understand it the Android terminology is that the downlink side of a call is the voice of the other party only, the uplink side of a call is the phone’s user only, and if you record “Voice Call” you should record both sides of the call.
So if you are recording downlink you are not supposed to hear your own voice.
If you are giving Audacity a valid file that is silent or nearly silent and it shows the correct length of audio, that is all you can expect of Audacity.
