Warning- Missing Audio Data Block File(s) message
Hi! I am desperate. I just recorded a podcast episode where I interviewed someone.
It’s about an hour and 9 min long and I did everything I usually do to save it.
When I opened the new Audacity window initially, I made sure to save the project before I even started it.
Then when I was done with the recording I went to file, save project and it was grayed out. So I then went to click save project as and then all of my stuff is completely gone. It shows that something should be there for the 1 hour and 8 min, but the actual audio is no longer there.
Then when I closed it and opened again, the message: Warning- Missing Audio Data Block File(s) popped up and I can’t find my audio anywhere.
Please please help me. I am desperate.
Thanks in advance.
Melissa
Which version of Audacity?
Which is what? (What are the exact steps that you do to save it?)
Which three-digit Audacity do you have?
