Hi,
I was wondering why a VST Plugin (32 bit) might work better in a different Audio program that, in general, is not as advanced as Audacity.
The initial issue I came across is that the option to listen to only the audio that the effect is removing doesn’t work in Audacity, but it does in the other software.
Maybe there is an option in Audacity that I have turned on that might interfere with a plugin. Just trying to troubleshoot.
Thanks,
Mike
