Curious if anyone knows this… I’m recording my voice and it comes out at a VERY low volume unless I speak very LOUD into the mic.
I have Windows XP and the mic input volume are maxed. I even do the monitor of the mic and the red bar only hits up at first sound, and then doesn’t come up anymore while it records
I did check the FAQs and nothing to help, anyone had experience with this?
Windows XP, computer microphone plugged directly into the Microphone input of the sound card.
In the Windows Mixer (speaker icon near clock) - select the “Recording Settings” and look for the microphone level. If it is not visible, look for “Preferences” or “Advanced” to make it visible. There should also be a “20dB Boost” or “Mic Boost” available - again this may initially be hidden.
